Making Winch Parts for M135/M211
dabtl
Denton, Texas
I have access to metal fabrication and I am considering making some of the winch parts for the M135/M211.
If anyone has the under cab support, the pilot bearing mount and pilot bearing shield that they can either take pics and measurements of or loan out, I will make some duplicates.
m1010plowboy
2,641
Edmonton, Canada
The Shaft
Tough job.
Here's a few photos. Looks like the mounting bracket has a 2" flange against the frame
and approx. 5.5" of surface area for the bearing.
Not sure if you're looking for the PTO cable mount location but it's right there.....there,
no over there.
Let me know what else you need.
Stan Leschert
90
North Vancouver, BC, Canada
That is the stuff, Digger Dave!
I have most of that (Cables and linkage not so much),
but it will be Spring until what I have gets installed ....
Just before Parade season!
I am so going to owe you a pint on your next trip through town!
dabtl
Denton, Texas
Those mounts are exactly the items I am speaking about. If someone has them out of the truck and can send them to me, I can make another dozen or so of the bearing mount, shield and cable support.
I doubt there is a big market for this stuff. But, I thought that when I made the first of the M35 gun ring cab reinforcement panels. That need turned out to be about 300 or so panels. I made nearly $5 per panel for the 30 or so I had constructed.
I can have the pilot bearing mount and shield easily made from just these photos. The under cab brace can be made easily if I can get the dimensions of it.
m1010plowboy
2,641
Edmonton, Canada
Is Canada near Dallas?
No wait, it's just your hockey team that's in our face all the time. You guys have great sports teams and if the ranchers had any sense they'd all have G749's.
Can you run an add on Craigs or similar with a pic of the truck and parts request. There's gotta be toys sitting in Texas fields. There's a few boneyards in Tuscon that had gear.
My local MVPA was my link to nearly everything I needed. The day I joined I spent the day in a motorpool warehouse full of ww2 gear and veteran 'restorians'.
Stan, is that the ocean I hear? ahhhh. . . . . . Where'd you dig up your winch parts?
Stan Leschert
90
We bought a winch a year ago with the driveline and pillow blocks.
This past fall my mechanic called me and asked if I wanted a winch for the Army Truck.
He had a spare winch cluttering his shop, and it came with the PTO.
So now 2 winches will become 1. Still have to fab the winch mounting brackets (That's why I made you send me pics),
and see if you can find me the control lever and cable from your secret hunting grounds.
:beer::driver::beer:
dabtl
Denton, Texas
I took the old pillow block bearing assembly into Purvis Industrial. I asked for a new one. Ten minutes later I walked out. Cost a few bucks, but what does not? Amazing.
m1010plowboy
2,641
Edmonton, Canada
Mounting bracket
It's nice when a plan comes together.
Do you have a part number for your replacement?
If it's different then the following it opens up some options.
nsk uc207-104d1
Here's a link I found when I googled the #.
http://www.seekpart.com/bearings/bal...gs/ucf207.html
I also have part # urs f206g Housing flange 4 bolt.
Total Price $32.37
I Took a closer look at the mounting bracket and front shaft.
Front Shaft
4' length 1 1/4" dia,
Mounting bracket
1/4" plate Comes with 2 1/2" mounting flange to frame
5 9/16" width x 6" ht.
1 1/2" 'center' hole and 3 3/4 On center bearing mounting holes.
The guard is 1/8" plate and extends 2 1'2" past the mount.
dabtl
Denton, Texas
I walked into Purvis Industrial with the old one. The lady at the counter took out some calipers, measured the shaft remainder diameter walked into the storage area for about five minutes and came out with the new one. She aligned the mounting holes on both and asked if I was happy!
It is a common industrial use. I will see about a part number and post it.
Thanks for the measurements. I am currently looking to duplicate at a metal fabrication shop the mount and shield. With the front shaft measurements I can seek out a custom drive shaft manufacturer if I cannot find an original.
dabtl
Denton, Texas
The part number for the pillow block bearing from Purvis is:
F4B-SC-104
An additional number on the label is 782475114634 which leads to the manufacturer, Dodge, and the item.
Made in the USA.
The shaft collar (stop) is available from McMaster-Carr as part #
9414T24
dabtl
Denton, Texas
Thanks Ron. I think they will be easy to re-produce. One more vital part I can have made.
It might be much easier to put a winch on the G749 version after all!!!
dabtl
Denton, Texas
Yup, nothing complicated. Good luck with the project!
The pillow bearing bracket and shield are at the fab shop now. I have to figure out if the bracket mount is angle cut as Fig. 343 in TM 8-8024 on the frame side or if there is enough room for a square cut bracket mount.
Is yours square cut on the frame side of the bracket?
