Making Winch Parts for M135/M211
dabtl
Denton, Texas
Do you mean the support bracket in fig. 344? That's the piece I sent. It's angled on both sides as pictured, but I don't think it would need to be.
Fig. 343 shows the pillow block bearing bracket labeled as G not the support bracket in Fig. 344.
dabtl
Denton, Texas
I am working on reproducing the bracket and shield. The first attempt is being done now. We will see how they come out.
This is not making an Iphone after all. rofl
Baradium
Salcha, Alaska
If there is anything else you need, we don't have our winch mounted due to the plow being in the way until we can cut off some brackets (for the plow, not the winch), but everything else is there on the truck still down to the driveshafts. Might make it easier to get measurements.
dabtl
Denton, Texas
I have obtained a couple of original parts for the winch drive line.
The in cab lever will be simple enough to make and cost around $25 to $50 depending on the number I have made. A pic of it is included here. It has a hole and attachment farther forward than the transfer lever and a bit of a curve to it.
The under cab brace will have to be made in two parts, welded, but would otherwise be very close to identical. Cost, about $75 down depending on how many get made.
I have the prototype pillow bearing bracket and shield now. Pics are included. Measure yours and tell me where we are off if you can.
dabtl
Denton, Texas
I am still not entirely certain on the pillow bearing bracket. If you could pull yours and either send it to me or compare the prototype measurements and shape to yours it would be helpful.
dabtl
Denton, Texas
I took some additional pics to show next to a tape measure. Can anyone measure theirs for comparison.
I already know we got the spacing wrong on the frame holes. They are 3.5" here and should be 4.5" center to center.
topo
277
farmington NM
My mount looks like it's 5 1/2 I could be wrong it's hard to see looking at it the angle .the bottom bolt looks to be centered at 3/4 inch from bottom of the plate . one of the pictures shows where the spring mounts for the master cylinder .and how far the drive line should be from the spring mount .
dabtl
Denton, Texas
I have measured the bolt holes to mount the bracket to the frame. 4.5 inch center to center, a bit offset on the bracket to allow a slight slant from top to rear, it appears. We will see how this fits.
dabtl
Denton, Texas
With little to do on a Sunday morning, I ran my usual searches on eBay. Then, for no real reason, I ran pillow block bearing, flange base. Same bearings, 1 1/4 shaft hole, as the parts houses stock. Cheaper!
Kind of amazing.
Then I went to Northern Tool. Even more amazing.
dabtl
Denton, Texas
I am having the under cab floor support bracket and J-Bolt shown in Fig. 344 of TM 9-8024 duplicated.
I expect to have them finished in a couple of weeks.
dabtl
Denton, Texas
Found a complete winch set up for the M135/M211 here. I will have the bracket by Saturday.
I will have pillow block brackets and shields by next week. Contact me off line.
m1010plowboy
2,957
Edmonton, Canada
Re-build PTO shaft U part #'s
These are the parts that we put into your pto shaft:[FONT=&quot][/FONT]
[FONT=&quot][/FONT]
5-170QG U-Joint[FONT=&quot][/FONT]
10-3-51X Slip Yoke [FONT=&quot][/FONT]
10-4-123QG End Yoke 1.250” x 0.312” Key[FONT=&quot][/FONT]
10-4-183QG End Yoke 1.250” x 0.250” Key
Hope this helps! [FONT=&quot][/FONT]
m1010plowboy
2,957
Edmonton, Canada
Winch shield
N- Shield Part # YT-2285374.................Duplication replicated.
After a long wait, the Shield for the PTO mid-shaft bearing is done. It's the first piece off the G-749 I tried to make a copy of, so we had to do it right. That's why it took 700+ days to get it on the plasma cutter and not because the owner of the plasma cutter now needs me, to do work for him.....so he finally got er done. The boys at Trim Industries were mad with oilfield work but now that things are different, it's easier to get important work done.
winch guard 15 012.jpgwinch guard 15 003.jpgwinch guard 15 004.jpgwinch guard 15 005.jpgwinch guard 15 009.jpgwinch guard 15 014.jpg
The original shield did not appear to be welded so we followed the exact design, including the sassy little gap down the inside edge. The pattern was loaded into the plasma cutter and saved for future needs. The 18G steel was a close match so it's a good lookin' reason to always have your shield.
m1010plowboy
2,957
Edmonton, Canada
That looks good!! What else are you going to start making?
After seeing what you're doing and given enough time and money, anything we want. I'm just waiting for you to build the scanner/printer for all of us so I can put an NOS part in the scanner side here....and you can run to the garage to get the part out of your parts printer.
I wonder how much longer we'll wait before NAPA or other progressive parts supplier has the replicating ability?
USMC 00-08
222
Skiatook, OK
I imagine the days of printed parts is not too far off.
Here is a teaser of what I am working on for the G749's. Getting enough free time on the machine to make several is the hard part right now. If I can't get many made, at least I will have the programs to do so later on.
