- 1,405
- 1,096
- 113
- State College, PA
The glow plug card works on a 12 volt system because the glow plug system is a 12 volt system.
In the stock CUCV config, the only part of the GP system that is 24 volt, is between the bus bar and the resistor. Once the relay is closed, the resistors and the glow plugs in combination with each other drop the voltage to 12 volts to each glow plug. You will have 24 volts to the top of the GP relay when the relay is open.
The best way to check glow plugs is to pull the wire off of each one and then test the resistance between the tab and ground. Typically they are between .8 to 1.2 ohms.
I would not change the fuel filter until the GP system issue is repaired. By doing this you may add another issue to the no start problem. Fix one issue at a time.
