manualing turning stuck mep-003 engine
scrapdaddy
11
Dittmer, Mo.
I've got a stuck engine on a 003 and have reading the threads on hand turning it. Is there some other way to turn over other than the bolt on the end of the blower. I tried that today and didn't like cranking down on that small of a bolt. I don't want to add to my trouble. I'm going to pull the injectors and add MM Oil for a few days. Thanks
R Racing
St. Leonard, MD
I haven't worked on a MPE 003 Yet but was wondering if you could try using a pry bar on the starter fly wheel . or compressed air thru the injector hole ? Good luck !
scrapdaddy
11
Dittmer, Mo.
Thanks, I need to look for an opening around the ring gear to use a pry bar. I'm not too sure about the air trick, never tried it before. I've got a few days to let the oil do it's thing, so I'll figure something out. That bolt on the end just doesn't seem big enough to lean on.
love-horsepower
indianola,iowa
stuck
take out glow plugs make sure not hydraulic locked w/ fuel or water . then spray lubracoat made by rectorseal it has yet failed to take anythiung loose i have sprayed it on if i can let it soak for a couple of days
PeterD
Jaffrey, NH
If you are lucky... (wish everyone was)
Remove glow plugs.
Pour in a small amount of 50/50 mixed ATF and Acetone. Turn engine so the pistons are down if possible.
Lightly screw in the glow plugs to prevent evaporation.
Let sit for a day or two or three.
Remove glow plugs.
Try to pry the crank over a bit. Work it back and forth.
Over the years I've broken free some massively stuck engines successfully. Usually a combination of things work to free them including the Acetone/ATF trick. If the head is off, light tapping on the piston can help too--the shocks help vibrate things loose.
But once it moves a tiny bit, just go back and forth and things should free up.
(instead of ATF/Acetone, you can use Kroil, which is excellent too... Both WD-40 and PB don't work worth a hoot, IMHO, and should not be even tried.)
ichudov
15
Chicagoland, IL
Lots of penetrating oil in cylinders
Let sit for a few days
Then use a pipe wrench on the shaft if you can get to it.
I also would not use the bolt.
scrapdaddy
11
Dittmer, Mo.
SUCCESS!! Just got one to turn over. I didn't want to put alot of torque on the 5/8 th bolt on the end of the crank, so I made a plate that fit inside the blower and drilled three holes to match the three studs and nuts that hold the blower on { I think }. I then welded a large nut right in the center of the plate . The plate slips over the three nuts and I bolted it down on the studs. Using a 1 7/16 ths socket, 3/4 drive and alittle bump, it turned right over. I did squirt some oil down the glow plug holes as told to this morning and it worked great. If any of you guys that have a mep-003 look at the blower guard, you will see what I'm trying to say.
As soon my son teachs me how to up load pictures, I will. If anyone is in the same fix just let me know and I can send the tool to you, it really worked great. Thanks for all the suggestions.
