mdainsd
- 25
- 18
- San Diego, CA
I am having a hard time with the two flexible lines that run from the left front frame rail to the hard lines on the engine, under the generator, that vent the master cylinder and the gas tank. I cannot find good illustrations of how they fit, mount etc.
From the length required it looks like the same ones used for the fuel filter might fit the job.
What do the experts use for these and are there supposed to be hard mounts on the frame similar to the way the brake lines transition between hard lines and flexible?
