Master Cylinder Push Rod Adjustment
dodjh
14
Central, MS.
Installing a new Brake Power Booster, tag says, "Master Cylinder Push Rod Adjustment must be checked for proper clearance."
How is this done? Thanks!
NDT
7,434
Camp Wood/LC, TX
The rod protruding from the booster, when at rest, should just barely touch the piston of the master cyl. If it pushes on it, brakes won’t release completely.
dodjh
14
Central, MS.
NDT, just watched a YT Video that showed how to make the adjustment. I should be able to do the adjustment (if it does protrude too far into the MC.) Thanks!
