Mastercool tools - any experience? Flaring tools in general?
F18hornetM
10
Ocean City, Md
I agree with you guys on how nice the tool is. My thoughts are, its to expensive for the number of times a normal person needs it. I work in a shop that maintains 400+ vehicles and we dont have one. Of course lots of air brakes, but anytime a hydraulic brake line is needed we just use the simple old, cheap double flare bar. I agree with no connections or at least as few as possible.
Just my 2 cents worth. I have used the hydraulic ones before, [demo] but I wouldnt spend the money on it unless I had brake lines to make everyday.
We also use the spring tubing benders, which are great if you need to route a long line.
Good luck with your truck:)
JGBallew
Paducah, Kentucky
paying attention to the cut end of the line, making sure it's cleaned up, etc will go a long way to producing a serviceable double with even a mediocre tool.
Seen people turn out a lot of crappy, split doubles with a beautiful benchtop flaring tool.
ZiggyO
489
Nebraska
My opinion is as follows:
I have bought alot of the smaller, lighter duty, cheaper tools in the past to get a certain job done. My experiences with these tools has mostly been less than satisfactory. In the end I decided to start getting the best tool possible for the job to be done-- I get better results and in the case of a light duty versus heavy duty tool, I have the ability to tackle a bigger job should it come along without having to buy a heavier tool in that case. Yes, this is an expensive route to take, and yes, I have tools that were only used for one job that are now sitting in the chest. However, in the long run, if I figure out all the money I spent on replacing tools I broke, had to replace due to poor quality results, or simply had to upgrade for a bigger job, I just about broke even. I like to think of it in the context of the tortise and the hare-- the "here and now" may put you ahead for a while, but may not be the way to go in the long run.
Now I am not saying to disavow the cheaper stuff completely-- there are times when the "get me home" fix warrants the cheaper stuff (and believe me, I do have my share of that stuff)...... The best example I can give is when I flew halfway across the country with a buddy of mine to grab a truck about 3 years ago-- I could not ship my tools out for cheaper than a set of harbor freight tools would cost me on site. Naturally I opted for the harbor freight tools to get me home and simply relegated them to under the seat in my suburban since...........
The best advice I can give you is to buy the best that: A) you can afford, and B) are comfortable laying out the money for.
Ziggy
deuceman51
10
Scotland South Dakota
For us it was a matter of time and money like someone else said. The time to buy premade lines with numberous joints that could leak. We did 2 our customers trucks with micro brakes installed, the location wouldn't work for a cheap type that needs more room to flare, ect. The mastercool set worked in the tight space and got it 1st time. The kit has paid for itself numberous times. I understand the average joe who wants to do one or 2 lines can't justify it. I was just saying it is a quality tool and well made in my opinion and experience.
derby
10
S.E. MI.
I have an old Imperial Eastman flare kit that has always preformed well.
You must........MUST follow the directions in order to get a perfect flare every time..........Don't forget the flare fitting before you flare it, you know how i know that.
Investing in a good tubing bender is always helpfull too.
I have never used the Mastercool brand. I try to buy what I know works.
Is the Mastercool an import?
F18hornetM
10
Ocean City, Md
Mastercool seems like they make good stuff. I have a AC manifold set from mastercraft and works well. NAPA sells it as well.
I wouldn't buy a cheap flaring bar either. You can buy a qualty set like this one that will make all the brake lines you ever need. [I have this one] Spend the difference in money on a 3/4" impact or some other tool you don't have.
Any rate good discussion, I like hearing others opinions/thoughts/Ideas.
Flaring/Cutting Kit - Flaring And Swaging Tools - Plumbing Tools - 4A518 : Grainger Industrial Supply
gimpyrobb
dumpsterlandingfromorbit!
27,786
770
Cincy Ohio
Agreed, but in my case, I've got one vehicle that needs fuel and brake lines, and two others (including my M1008 ) that will almost certainly need similar work.
And then, there may be trans lines that need to be replaced, too.
For my civvyChevy, the dealer wants $265 just for the fuel return line, and that's not counting the delivery line!
Yes, I know I can make it myself using pre-flared sections, but that would leave me with a lot of unnecessary joints.
I think for me it makes sense at this point. I can do all three vehicles correctly, and then maybe sell the tool and recoup part of the investment.
At least, that's what I'm telling myself! :mrgreen:
Sometimes, the right tool for the job costs money. I don't like laying out that much for one tool, but I am usually glad I did everytime that I use it!
MarcusOReallyus
819
Virginia
My Dad always said that cheap tools are false economy.
After visiting my parts store and confirming that I can't buy bendable tubing with the GM fuel fitting type flare on it (which I need for my civvyChevy), I ordered the Mastercool from Tooltopia. It was only $20 or so more than getting it from some nameless Amazon seller, and for something like this I want to be sure I'm dealing with a reputable company.
I'll post results when I put it to work!
Thanks for all the input, gentlemen! :beer:
1,138
I've never regretted buying tools and I don't buy cheap stuff.
You may not use it again for 5 years, but on a Saturday night when you need it, it's in the toolbox and it's priceless.
