Another status update:
Well, the weather continues to stuck around here. Pretty much has rained everyday this week and last weekend. Progress has been slow...Today is the first nice day in a while, although its supposed to storm tonight but who knows anymore. I did however get 1 mudflap installed on Tuesday (pics to follow this weekend) I got them from Northern Tool 24" x 30" (about 13$ each -rubber). I had to measure up the mounting holes and used a standard drill. I do however need some washers to make them flush with the head of the bolts, but overall I really like the appearance of them. There a lot better then the stock military ones. (mine were starting to fall apart). There the floppy kind you would typically see on a dumptruck.
As far as sanding and painting goes. I decided after the first bag of sand for pressure sanding, I'm going to use that method for the "hard to reach" or small pieces, (i.e. the frame rails and even the wheels, exterior bits). The bumper on my truck has so many coats of paint it was taking forever to get to bare metal. Yes, this process works very well, its just really time consuming... But the after results are going to be worth it! Also I burned through a 50lb bag just to do a section of the bumper and part of the hood. It does use a lot of sand.......
So for the bumper I'm going to try some paint stripper to "get rid" of a few extra layers to see how that works.
Photos of the truck to follow this weekend (if the weather cooperates)
Justin
