maybe the pink wire?
scrambled
Marietta,Ga
TI am spending the day helping a friend with his 1008 and am running into a problem. I left my copy of the TM at home, and the only internet we have is on my little phone. YAY!
I am having a hard time getting the glowplug relay to close. It is a brand new napa st85. I have good voltage at the top post. We installed a push button to work the relay. The switch does not worrk. My ground is good. I even ran a wire from the top small terminal and tried grounding that way, but no dice.
Is there suppossed to be voltage at the pink wire on the lower small terminal?
i hate to head home for the tm, but that might be my best option.
thanks,
travis
scrambled
Marietta,Ga
It must be a switchable hot. As soon as you hit it with 12 volts, everything works as it should. Now to find why is has no power....
Warthog
227
OKC, OK
The pink wire for the GP relay is controlled by the ignition switch. The switch has to be in the run/start position before there is power.
