kassim503
- 3
- 0
- Stony Brook, NY
I have recently purchased a MC-7 Davey compressor, and from what I read its Davey Model 14M125. The tags have been removed as the previous owner "De-Militarized" it, but it has a john deere 3 Cyl diesel and a rotary vane Davey Compressor on the back. I went to change the hydraulic oil in the air end with a fresh fluid and filter, and may have overfilled the unit. My motivation was that the military models have a decal on the oil tank that says "Fill to Overflowing," and I did as such. Unfortunately the air outlet blows a mix of hydraulic oil and air at the same time now, which is usually an indication of the in tank air/oil separator filter failure. Does anybody know a PN for this filter?
Also I filled it with cheapo AW46 Oil as per the cross reference from the MIL- number spec'd in the TM for a 6M125. Help!
