alot of talk about towing the M105A3...... hauled mine from Barstow to Las Vegas almost 200 miles....F150 no issue.... pintel hitch and mag lights for markers the stuck right to the top of the tail gate..... passed CHiP on the way back on 15north...no issue at all. had a flat spot on one tire where they dragged it with an emergency brake still activated, made for a bumpy ride but after getting up to speed 70-75mph had no problem could hardly tell trailer or flat spot was there.
Now what to do with it.... I have seen lots of ideas and suggestions here.....
We are making this into a extreme off road trailer for desert survival camping.
Pull vehicle will be a 2015 Jeep Rubicon with 37" and 4.5 Rubicon Extreme Long Arm Kit
we will be removing the box..... so anyone needing or wanting a great condition box let me know.
building on the frame a 40"Wx90"Lx32"H aluminum box no wider than the frame rails with a fold out platform on top for tent.
In front of the box will be a 18 gal water tank and pump, Yamaha camp generator, propane tank, on demand hot-water system from campers world, air compressor, converting all electric to 12 volt with two onboard batteries and a solar panel too, LED lights inside and outside the box.
questions I have already gotten answer to.....
Brake system........convert and use Titan BrakeRite II SD Severe Duty Replacement Brake Controller #4834100 http://www.trailerandtruckparts.com/...l#.VKNvenuJiUk
Electrical....rewire for civilian 12 volt LED lights
hitch..... going to look at Lock-N-Roll..... they seem to have a nice full articulation hitch only he would have to retrofit it to the trailer. https://locknroll.com/
still need to find rims for the trailer that are not split ring, extensive search has come up with NOTHING......any Ideas?
TobyLogic
TobyLogic
