Mechanical Booster Pump "making oil"
yolner
68
Rockville, MD
OK
Got mine in the mail today, $35.00 including shipping. AMBAC # KT9062
Looking at the pictures of the kit and the pump I just took apart I can't figure out where the o-ring and the round yellow gasket piece are supposed to fit. I took my pump apart and all i found is the seal and the snapring. I did check the TM and I don't see them on there unless they're under the "valve screw" piece on the side. Can anyone confirm?
EDIT: Ok, found the o-ring on the valve screw. Still don't see the yellow washer/gasket anywhere.
Stranger
Weatherford, OK
Correct. They are under the valve screw. That yellow gasket is the "preformed packing" (Item P) on diagram 3-43 (Page 3-32).
yolner
68
Rockville, MD
Ok so here's my valve screw. The o-ring is right there, but no gasket unless it's sandwiched between the silver tip and the black part. Anyone know how this thing comes apart to replace the gasket? Don't want to break it.
EDIT: Looks like the silver part was just stuck to the gasket. I smacked it on a piece of wood and it popped off. Mystery solved!
frank8003
4,989
Ft. Lauderdale, Florida
So this is the one of five ways to be "making oil" with a Deuce multi fuel.
A little seal to stop from engine destruction.
So looks like to cure the problem you need a little KIT from AMBAC KT9062
Looks the same for all of the different booster pump series and same for ONAN MEP003 pumps
So see the nice pictures and read the PDF and the KIT is now on a popular site see that they are now on a auction auction site for 24 bucks delivered.
I am not sure that all this was fun but I needed to know.
View attachment booster pump seal.pdf
rustystud
3,374
Woodinville, Washington
Thanks Frank ! I needed to finish rebuilding a couple of boost pumps, and now I can.
Gnepig
Fla
The kit I found on that online auction site that starts with an e, says it's a KT 9062 Mack model 300- is this the one I need or am I looking in the wrong place?
Gnepig
Fla
I've also found the HH o rings on the same auction site, are the Viton one's good or should I just use rubber?
Also someone said it would be easier to remove the IP to change these parts than to move the whole engine, is this correct?
texas30cal
87
Brenham Tx.
I just rebuilt the pump on my truck last weekend, I didn't move the motor at all, I pulled the drivers fender for easier access (no ladder needed). I pulled the steering wheel, disconnected turn signal, loosened the column mount on the dash, pulled the 4 bolts securing the column to the steering box and slid the column up. The steering shaft will stay behind in the box but you can remove the cover and one gear from the pump then rotate the pump housing ccw until it's nearly upside down. It wouldn't quite come out but using a prybar to push the steering shaft away from the IP just a little was all it needed to come out. It was really quite easy. Do not turn the wheel after removing the 4 bolts securing the column as the shaft will try to screw itself up and out of the gearbox, it may not hurt but I'm not sure so prob best to keep it in the box. Also be careful with the column shims and put rags in the opening around the steering shaft to keep out dirt and foreign objects.
rustystud
3,374
No. Leave the injection pump alone. The Hydraulic Head comes out pretty easy after you align up the marks.
gimpyrobb
dumpsterlandingfromorbit!
27,787
778
Cincy Ohio
I think he is planning on doing the fuel pump too. Its really a pita to work with, with the IP on the motor.
Floridianson
2,526
Interlachen Fl.
Also gives you the chance to change out the rubber IP oil feed line. I still believe the IP can be taken out without removing fenders or radiator. Yes you have to be able to touch your toes and have a bench to stand on and lay across the fender for awhile. Yes skinny boys with the right tools have the advantage sometime.
gimpyrobb
27,787
778
Cincy Ohio
I pull the IP without pulling the rad or fender. It can be a huge pita if you have a heater mounted there though(inner fender).
I might have an oil hose kit or two still, if interested, PM me.
Floridianson
2,526
Interlachen Fl.
Yep just lay the heater over the motor leaving the lines attached is what I did. It is tight working and not much fun but it can be done. I have a set of steps that put my waist just at the right height to be able to bend over and put my chubby belly on the fender.
rustystud
3,374
Hey those "chubby bellies" come in handy as a buffer against things like hard fenders ! Kind of like having a built-in pillow !
Gnepig
Fla
I suppose that replacing the seal in the booster pump would be a good idea, thats why the question about the IP removal.
I am equipped with one of those "chubby bellies"...
