- 3,701
- 5,543
- 113
- MA
I recall seeing a thread (and I think a SS member used to make a kit) to remove the OEM canisters and get an upgraded filtration system in place. Anyone help me recollect what I read? Thanks
Looks good! Thanks for sharing the part #'s. I might give that a try one of these days.Here's what i did.
Did you need any fittings to mate the stock fuel lines to this, or was it drilled to accept the same size? Did the remote base come with mounting bolts?Here's what i did.
WIX 33405/ NAPA 3405 - 14 Micron Fuel/Water Separator Filter
WIX 33352/NAPA 3352 - 6 Micron Filter
NAPA GOLD 4770 - Remote Mount Spin-On Filter Bases
I also found a 2 micron filter after i ordered the others that i will get for spare.
WIX 33528/NAPA 3528 - 2 Micron Filter
Yes I think so. ThanksWas it Speddmon?
I don’t recall right now if I needed anything special or adapters, I’ll go look at it in the morning. I think i reused the fittings from the stock filters and just used some reducers for the 90’s to fit the bases. But I’ll get you a definite answer tomorrow.Did you need any fittings to mate the stock fuel lines to this, or was it drilled to accept the same size? Did the remote base come with mounting bolts?
That's a viable alternative. Change the primary more often then the secondary. But a water separator with a glass bowl is for me a must. I want to SEE what the fuel looks like.What we used to do at work was have a 5 micron primary and a 1 micron secondary filter.
Sent from my SM-G950U using Tapatalk
Oh definitely, ever since i lost my xray vision the glass bowls have been amazing.That's a viable alternative. Change the primary more often then the secondary. But a water separator with a glass bowl is for me a must. I want to SEE what the fuel looks like.
LITD, yes the bases are 1/2" NPT and i think the 90's were 1/4" NPT??? i'll go see if i have one laying around in the garage somewhere that i can confirm.... I'm pretty sure i got the reducers from Lowes, so its a common size.... (i think)Any update on reducers needed? Looks like its 1/2" NPT on the NAPA base part called out above. I think the lines from the pumps to the filters are 5/16 JIC if anyone cares to confirm before I break out the books.
If you could that would be great. I have spare elbows here, but can't seem to find my thread gauge tool.
