MEP 002/3 a fuel pumps...
Keith_J
1,327
Schertz TX
Why do these gen sets have three fuel pumps? Because they have SIX filters and strainers! Yes, two elements, a strainer+water separator and each fuel pump has a fine strainer.
The bottoms come off with a twist, then the filter is inside. If you are having fueling issues, check these as they can get plugged.
Speddmon
Blind squirrel rehabiltator
30
Cambridge, Ohio
there are 2 lift pumps and one aux pump, just done for redundancy. The set can run just fine with 1 lift pimp, but if the military were running some critical equipment like a field hospital, I think they would be very very upset if they lost power due to a bad fuel pump. The odds of both fuel pumps going bad at one time on a running set...unlikely.
