dangier
- 7
- 18
- Page County, VA
Today I had been running a load test breaking in the new pistons and re-installed rings on my latest 002 and noticed the q3 transistor on the AC power regulator board (5020), is very hot running at 60hz. Could not hold my finger on it for very long. Is this normal as it has a heat sink or am I heading for a replacement? All other components on the board feel cool. I had previously replaced the r11 resistor and cr2 diode as they were burned. Unit is now making good power and had a 240v load bank up to about 6960 watts load (576w inductive/6384w resistive), without the engine lugging down. Load meter showed around 120%. Ran this way for about a half hour, then back to 5000w for an hour and half. Probably could have increased the load in smaller increments using work flood lights, but was worried about the q3.
This is the one with the cracked pushrod tube. Cleaned the crack and sealed with rtv until I can get a replacement tube. No oil leaks during a 2 hour run.
Thanks,
David
Thanks,
David
