RichardR
- 3
- 8
- Austin, TX
Hello all you MEP-002, 003 experts,
I have experienced several fuel pump failures on MEP-003A generators, and I wonder if anyone else has had a similar experience. The fuel pumps I am talking about are the low pressure 24 Volt oscillating piston pumps, located below the control box, that suck fuel out of the tank and deliver it to the filters at about 5 to 10 psi. I notice that there are at least two slightly different versions of this pump, one with a small cigar-shaped EMI filter in the power line and the other with a cube-shaped EMI filter. They are shown in the attached pictures. The one with the cube EMI filter is stamped Facet 480517E, and I don't find a similar stamping on the other kind with the cigar-shaped EMI filter although it may just be covered with CARC. THE TM calls out part number 480517.
I have had 3 of the cube-shaped EMI filters develop internal hard shorts to ground. And one of the 480517E pumps (before removal of the soon-to-fail cube EMI filter) failed in its internal electronics (wouldn't turn off the magnet to let the plunger return to its non-energized position). All of these pumps had been cleaned and were operating normally just before sudden failure. And all failures happened within about the first hour of operation (after perhaps years of non-use).
I think the "E" pumps with the cube EMI filter are the latest version of the pump, replacing the version with the cigar-shaped EMI filter. Seems like most of the "fresh" resets have one or more of the "E" pumps, which look newer than any pump with the cigar-shaped EMI filter.
Has anyone else had problems with the "E" pumps and the cube EMI filter? I think I would rather stay with the older version (cigar EMI filter) because I have never (yet) had a problem with them. Of course, all these pumps get varnished up and stuck if not used often enough, but I don't think that has caused any of the problems I have experienced.
Thanks for reading this long-winded post, and for any advice/preference feedback on what's going on with my pumps.
Richard
Richard
