MEP-002A, 003A Fuel Pump Failures
Isaac-1
SW, Louisiana
Well the gasket and filters arrived today, I installed them and everything looks great, while I was at it I noted that all 3 of my pumps have the cigar shaped RF filters. I also installed the new fuel filter on the MEP-016d, this was not fun, it is a small filter inside the fuel tank and has to be removed and installed through the little fuel tank fill neck, thankfully I found that I had an offset dogleg box wrench that would fit the top of the filter and allowed me to position it to install the new one.
Ike
p.s. the MEP-016d now runs
RichL
elwood, nj
mep-002a fuel pump
Just had this problem today. Started generator only to have it shutdown after a couple minutes. Turned out the Negative battery teminal came off. Put terminal on, tighten it down, DC breaker kicks. Reset breaker, kicked again when I tried to start. Long story short, my pump was shorting out. Ever here of that.
Uloadit
12
Swansea Ma
That happened to me just cut out the wire on each end of the square box and run the wire off the pump and to the wire to the plug end eliminating the square box that is the noise suppressor
Speddmon
Blind squirrel rehabiltator
Cambridge, Ohio
Yes, we have heard of that before....many times as a matter of fact. Do some more reading on the forum here and you'll see that you never want to unhook your battery while the set is running, intentionally or not. You'll be lucky if the only thing that got fried was the noise suppressor on the fuel pump.
