catman393
- 0
- 1
- Portsmouth, RI
Hello All,
I'm trying to verify that I have properly troubleshot my DC Charging System.
My measurements are:
Resistance Between Stator Leads (disconnected) - 0.9 Ω
Left hand lead to ground - OPEN
Right hand lead to ground - OPEN
Stator disconnected and engine running - 43.2 VAC
DC Voltage regulator red banded wire - 25.97 VDC
Batteries - 25.99VDC (13.14 VDC & 12.86VDC)
Stator connected and engine running - 2.215 VAC.
From the various threads on here and Smokstak I've read regarding this issue it's either a bad stator (yuck) or a bad DC VR ($$).
Can someone confirm one way or another? Are there any other reading at TB-6 I can take to verify/narrow it down?
At one point I'm fairly certain the charging system did work but I can't 100% confirm that.
Thank you all in advance.
