MEP-002A flywheel access
Speddmon
Blind squirrel rehabiltator
Cambridge, Ohio
There is supposed to be an access window and pointer on the side of the bell housing on the opposite side from the starter.
jbk
livingston la.
remove the plastic center plug on the front grill insert 1/2 inch socket and rotate clockwise to bring it into veiw on the flywheel.
epitts
Terre Haute, Indiana
[ QUOTE" remove the plastic center plug on the front grill insert 1/2 inch socket and rotate clockwise to bring it into veiw on the flywheel.
I found the window with the pointer, now I will look for the plastic plug.
Thanks for the help
Speddmon
Cambridge, Ohio
You may not have the plastic plug. The hole referred to is on the cover for the cooling fan on the "Front" of the generator set (Front being the end of the enging opposite of the control panel, I know it's backwards, but that's what the TM designates as the front)
epitts
Blower cover
I did not think of the fan nut. Was not sure it was strong enough to turn the engine over. Will give it a try. Sorry for all the FNG questions, always learning somthing new.
Thanks
