Yes it is messed up, I remember seeing it looking strange, how do I fix it? I could not find anything on youtube? How do I get a rebuild kit?They are pretty easy to rebuild. The one that is not building pressure probably has a stuck check ball in it.
Take the bottom cap off and remove the strainer, then you will see the wire clip that holds everything together.
There is a plastic check ball on both ends, if either is stuck the pump won't work properly.
Perfect advise! The washer was work making the ball sit sideways, it's fixed so now I have two fuel pumps, there connected to each other, and they both power on at the same time, is this okay/normal?Yes it is messed up, I remember seeing it looking strange, how do I fix it? I could not find anything on youtube? How do I get a rebuild kit?
Yes. 2 work together. The 3rd only in aux fuelPerfect advise! The washer was work making the ball sit sideways, it's fixed so now I have two fuel pumps, there connected to each other, and they both power on at the same time, is this okay/normal?
Something went to ground. without looking at it in person i would suspect the thermostat was grounding.So this am went to start it with the plug, plugged into the wax thermostat and it burned through the ground strap, almost caught the whole thing on fire. Any advice? Maybe related or maybe not?![]()
Sent from my SM-N960U using Tapatalk
I hope by this you mean adjusting the governor settings to maintain 60hz with the proper droop adjustment as outlined in the TM. These generators should NEVER run at an idle. 1800 rpm out the gate all the way to shut down, or your voltage regulator might tell the tale.Last thing to do to finish this restore is to adjust the throttle/idle!
In particular, PDF page #'s 102, 104See section 7-3 of TM 5-6115-584-34
7-3. EXTERNAL GOVERNOR PARTS AND SPEED
CONTROL ASSEMBLY.
