glassk
- 0
- 38
- Hampton, GA
I did use Mr Edwards photo, without first getting permission, hope that was ok,..
One would have to make a bracket and mount a N/O pushbutton so that it is made when breaker is open/off, then low voltage lines to the oil pressure cicuit in series would only let generator stay running with oil pressure and breaker open, of course 600 feet may need a relay in series with oil switch and operated by push button, either way it would be no forgetting or someone starting without knowing the setup, just a thought because Linemen are already out in the weather that makes running the genset needed,..
