I have attached the repair TM for the MEP002A, if you check adobe page#'s 135 to 146 or TM page 7-30 to 7-41 it shows the IP removal and repair. You IP guts most likely will NOT look like the diagram. Before you remove it from the genny block, crack loose the 4 allen bolts and crack loose the nut looking thing in the center on the front of the pump, this is the delievery valve, then take off the IP. I hope you have not taken off the nut caps on the injectors and used an allen wrench and turned the injector adjustment pressure, DON"T turn the allens. This is how to dissassemble the injectors, but you need a test machine that I don't know know where to locate. Do you have an arbor press? To take the IP appart, remove the four allen bolts, take out the cup plunger that the cam lobe rides on that is in the center of the drive gear on the back, it has a lip, pull with your finger nails or gently pry with a screwdriver, it is just slid in with oil suction and tight tolerances working against you. Under this is the timing button, with a snap ring, use a point tool to work it out. Under this is the drive shaft that at this end is cup, lock teeth, ring plate. What? There is a spring that has the drive shaft in its center, on the top of the spring is a mounting disk with keeper teeth that bite into the drive shaft. When the engine spins it turns the drive gear that operates the timing of fuel delievery, the cam slapping on the timing button pushes the drive shaft in and out like a piston which presurizes the fuel to go to the injectors. The drive shaft is round except for one side which is flat that a drive washer is turned by. The drive shaft/piston has to turn to open and close ports to send fuel to the right injector. So heres the deal; however you can compress the spring plate to release the two keeper teeth on the drive shaft/piston, pull the two teeth out, take off the spring plate, and spring. There may be washers throughout this unit that I am forgetting about, KEEP TRACK. Take off the delievery nut on the front you loosened, there is a spring, needle, maybe a shim washer here pay attention. You need to be sure to take out the throttle control lever, there is a keeper bolt and plate, the lever will slide out, but may be stuck. Take off the four allen bolts on the front, the internal frame is a cylinder inside of the square housing. With the throttle linkage off, if anyone doesn't disagree, gently press the drive gear tward the outside to get the drive gear internal assembly to slide out tward the delievery valve side. This internal cylinder is held tight to the outer housing by the pressure of two O rings to seal in the fuel. NOW, check out how it looks, there is a keeper snap ring channeled C clip that holds the drive gear to the internal unit. Gently pry this off keeping it in line with its self not to warp it. You should now be able to remove the drive gear. What is probably the root of your issues is the cross drive plate that the drive gear turns to turn the "dog house shaped piston shaft". You need to free up this shaft, it should spin and pulsate in and out hense presurizing fuel at the delievery valve. You need to slide out this piston shaft but there is the throttle donut in the middle cavity that has to go on ONE way ther is a dimple drilled on one side, put it back facing the same way! I had to carefully pound out the piston shaft, its all tight tolerances but should be free enough to slide and spin. What is under the drive gear? There should be the cross shaped washer, is it broken in two? It needs to be welded and ground back to shape, like I said this allows the drive gear to turn the shaft while the cam lobe pulsates the shaft in and out. Clean everything and assemble lubricated with diesel fuel and the O rings with vasoline or grease. Did you notice the tit on the inside of the throttle linkage, this rides inside of the channel groove on the donut, when reassembeling you must make sure the tit goes into the channel. The two O rings on the cylinder housing are delicate to reinstall with out shearing them off. Doughnut right way, throttle tit in doughnut channel after cylinder pressed into mounting housing, carefull O ring press into housing. Install cross washer, drive gear and its C clip, compress piston spring and install keepers. There is a screw on the side of the IP housing with a copper washer, remove screw and turn drive gear until a thin wire catches into a timing slot in the drive gear, that is what is the slot on the side of the gear. This is for timing the IP to the engine. Keep the gear and wire in this position for install. The engine needs to be turned so that the #1 cylinder is on a compression stroke with the PC marking on the pointer to the left of the IP on the block. Read the TM on timing the pump. You can turn the crank with the nut on the front of the air intake fan. Direction to turn to suck air into the motor. If you remove the #1 injector you can see if the piston is up. The PC mark will line up on a compression stroke and an exhaust stroke so you need the piston up and the cam lobe in the position of pushing onto the timing button on the IP. Read the Tm. This is not precicely order of work but its the basic idea, you''ll see how to go when you LOOK at things when you take them appart. Tight tolerances and need to be lubed with fuel. What did I miss? Yours was probably gummed up and stuck and probably blew the cross drive washer. Good luck, let me know how it goes, keep it CLEAN.
![Cool 8) 8)](https://www.steelsoldiers.com/images/smilies/icon_cool.gif)
