heritageequipment
- 3
- 3
- Morgantown, PA
Hello,
We have a few MEP-002s that bog down with only 2-4kw when using the load bank but run perfectly fine otherwise. I have tested some that went up to 7500w. The manuals simply says to check the air filter if they have low power. Is there a thread or check list to know where to start with low power output? Actually one of them has a brand new crate engine (well military rebuild) that we put on the unit and it wont put out more than 2k without bogging down.
Rebuilt engine unit
-Governor is very tricky to adjust on this one, It either overspeeds the one direction or bogs the other, I cant get it to hunt.
-bogs at 2kw
-super clean...well it just came out of a crate!
1500 hour unit
- Governor adjustment works well, it hunts one direction and droops the other, and I think I found a sweet spot in between
- bogs down at 3-4kw
-once it starts bogging you can push on the linkage to get it to speed back up
Both units start right up with and dont smoke at all
What is the flow chart of diagnosing low power units? What order should I do the following things, or what else do I need to add to this list?
1. Check compression
2. have injectors pressure set
3. check fuel pressure to injection pump with gauge
4 check valve lash
5. Check injection pump timing
6. injection pump output pressure
7. ?
The injection pump timing procedure looks like voodoo magic to me....so I would like to save that for a last resort, lol
Rebuilt engine unit
-bogs at 2kw
1500 hour unit
4 check valve lash
7. ?
