- 1,308
- 1,681
- 113
- Basehor, KS
The Triplet Model 60 Meter here has a switch. V-mA / 2 and V-A-Ohm
The way this works is as follows:
you select the range you want to measure.
in our case @ckesey selected 100VAC
The black top scale above mirror is the scale we would read which is either
0 to 10 or 0 to 5
since we selected the 100V range, the indicated voltage has to be multiplied by 10 for a maximum reading at scale end of 10 x 10 =100
this is for the range switch set to
V-Ohm-mA
If we set range switch to V-mA / 2 then the voltage range is 100V / 2 = 50V
and we would use the numbers 0 to 5 on the black scale above mirror
so the scale shows 3.5 x 10 =35 VAC
So, it’s 35VAC and stator is good
0 to 10 or 0 to 5
V-Ohm-mA
