Mep-003a fuel injector gaskets
Dog Breath
154
33
Wisconsin
I need around 20 of the 147-0043 gaskets. The most reasonable price I have found is $4 per at equipment parts sales in PA. Are there any other sources out there?
Ray70
6,991
West greenwich/RI
They are available direct from Cummins on line but $4 is probably pretty close to the going rate.
Equipment parts sales gets $4
Cummins seems to be $5.50
GMG is $15.20 ( insert you own joke here )
Dog Breath
154
33
Wisconsin
Ok great thanks Ray. I disassembled 8 nasty/stubborn/plugged 003 injectors and cleaned them. They are all set to about 1800 psi and spraying a mist.
I also just popped out the two fan side injectors on my first 003. It ran fine once warmed up but smoked white on startup for a minute or two. They were at 1400psi so I cleaned and set to 1750-1800 psi. It now starts like a champ with little 💨.
very happy with the results so far
