MEP-003a Fuel Pump
EnteJager
NJ
I still had my search up from napa with that number in ti and it was a no-go.
Closed and opened the window and tried again and got your page, if I can't find a facet that will work I will try one of these. Thanks for checking.
Dave
I went to napaonline.com, put "p74016" in the search box, and it came up with a $56 universal pump. Is that not what you seek?
Speddmon
Blind squirrel rehabiltator
32
Cambridge, Ohio
I found a pump that might work, does the 1/4 18 EXT vs the 1/4 18 INT make a difference?
Thanks,
Dave
The 1/4-18 EXT and 1/4-18 INT is just a male or female national pipe thread (NPT). The EXT one is going to be a male thread, and the INT one the female. You can get the proper adapters to convert from NPT to JIC at the Parker Store, or any place near you that sells hydraulic fittings. Get the pump and then you can get the fittings you need accordingly.
EnteJager
NJ
Thanks, that is what I was hoping, I picked up a facet that is identical to the one on the genset, except for the INT, EXT. 50.00 was alot cheaper than the alt. to get a direct replacement.
Dave
