ChesapeakeJohnny
- 0
- 1
- Eastern Shore, MD
Hah! I got confused about what I was confused about!!
I am clear now, but have learned from this series of comments that I need to remove the earth ground from the main panel and put it on the utility-side neutral of the transfer switch.
Your explanation (and help) are much appreciated. We have an electrician coming to do the install, but I wanted to make sure we were doing it right. Seems like laymen aren't the only ones who mess these installs up.
There you go thinking too much into it again....remember, the switch you are using switches the neutral...so, when you are on utility power, the neutral coming from the generator is not used. It's not connected to anything because of the nature of the switch, so it does nothing...can't have any double neutral-ground bond on a wire that goes nowhere.
