RichardR
- 3
- 8
- Austin, TX
Looking for some help from all the smart diesel engine folks on this forum ...
I have a recently rebuilt MEP-003A with about 10 hours on the clock that runs very well except that the engine seems to miss a beat about every 10 to 20 seconds It misfires just enough to cause a slight dip on the Hz meter and a brief compensating throttle jog up from the governor. Then after the very brief interruption (which I suppose may be only a single cylinder misfire) everything returns to normal until the next unpredictable event. There is no exhaust smoke or other external evidence to help track down what or where is the source of this problem.
I bought this unit from a Federal agency that was trying to use it to run video equipment out in the boondocks, but they couldn't get the video equipment to work with the power frequency glitches so they gave up on it. It was a fresh rebuild when they acquired it, so I suppose it has exhibited this behavior ever since it was rebuilt.
I first suspected that air bubbles were getting into the fuel supply to the Injector Pump, but I have now thoroughly checked out the fuel supply at the IP input and am quite sure that is not the problem. There is lots of fuel flow and no bubbles into the IP. I also flow-tested the IP timing and found it to be very close (as close as I would be able to get it if I were to do it from scratch) so I don't think IP timing is the problem.
There is still a long list of things I can think of to do, including:
1. change the fuel to a fresh supply.
2. look for a sticking valve by removing the valve covers to assure adequate lubrication in that area, taking off the rocker arms and valve springs, and seeing that the valves slide properly in their guides.
3. I am thinking that the valves seat properly and the rings are good since this is a recent rebuild, but I could check cylinder compression.
4. change the IP to a known good unit, but that will require me getting a proper button unless I get lucky and happen to have the right button.
5. run the snot out of it under heavy load in the hope that it will fix itself.
6. etc., etc.
But life is too short and there must be at least someone on this forum who can point me in the right direction. HELP, please. Has anyone ever seen a problem like this?
Thanks for reading this long-winded post and thanks for any wisdom you can provide,
Richard
6. etc., etc.
Richard
