MEP 003A not getting 240v
JeremyDM
New York
If the switch is actually stuck, you might want to try a can of aerosol contact cleaner.
Thanks for all your help! It was the switch that was locked up. A little TLC was the trick and maybe a bit of electrical contact cleaner spray! Working the shaft back and forth with vise grips on it and using some inward pressure while turning and WALA it started to “CLUNK” going into each position!
