MEP-003A oil pressure gauge hiding from me
bones1
Southern Maryland
Just received my MEP-003A with ASK kit installed. Is there supposed to be an oil pressure gauge somewhere?.
And also, where is the L0 neutral bonding strap located? Is it behind the white panel with the lugs?
jamawieb
522
Ripley/TN
Flip the access door on the top of the ASK. Then look inside and to the right, if your standing directly in front of the unit. Its in the same location as any other 003a.
DieselAddict
1,902
Efland, NC
I had considered putting a low oil pressure light on the panel of mine or relocating the oil pressure gauge so I knew when it had built enough pressure to let go of the start switch.
cuad4u
88
St Matthews, SC
On ASK units it is a relatively simple matter to relocate the oil pressure gauge just under the gauge panel near the throttle. I used a chrome gauge mount from NAPA - about $3.
jamawieb
522
Ripley/TN
I've had a couple of military modified units, where they relocated the oil gauge right under the control panel next to the throttle (a logical place).
bones1
Southern Maryland
Thanks for the info guys. You can tell that this is my first military generator purchase I bet. Some more then. That hatch on the top marked "air intake" on the ASK, should that be open when running? .Moving the gauge to the front panel is an excellent idea. So the bonding strap is on the backside of the grounding lug down by the 24v slave receptacle. Thank You all.
bones1
Southern Maryland
Never did find the oil pressure gauge. Must be hidden under the ASK kit somewhere. I guess if it didn't have good pressure the switch wouldn't let it run. All must be well, it runs really nice.
DieselAddict
1,902
Efland, NC
If you open the top hatch covering the air cleaner you should be able to see it along the right side down low. It may take a flashlight to get enough light down there to find it.
