MEP-003A
truckfest
glenmoore pa
I cannot find a new oil filter canister gasket for the Onan Diesel. Am almost to the point of having them made. Would like to find a parts manual for the MEP-003A. Any help would be greatly appreciates. First post, hope it's ok.
Thanks,
Jeff
LanceRobson
206
Pinnacle, Stokes County, NC
Onan is pretty proud of their parts when it comes to pricing them but they usually do a good job of keeping them in stock.
I'd suggest getting the model and specification info off the engine (if available) and calling or emailing them. If that info is not available (and my brain cell recalls correctly) they have military products contact link on their main website.
Lance
papercu
31
Baxley, Ga.
Welcome, The gasket should be with the filter. This is the info I have, hope it helps. Wayne
Gasket, oil filter assembly NSN is 5330-01-200-4808 part number 102940 (Manufacturer code 73370 Fram Corp)
Oil Filter: NAPA 1004, Wix 202 C, Fram CH6PL, military p/n MS35802-2
NSN 2940-00-580-6304
CGarbee
524
Raleigh, NC
I purchased a set of manuals on CD a while back that seems to cover every one from the 1.5kw 28v units on up to the 200kw 110/220/440 units made up through the early nineties... I want to say that I purchased it from Military-Media, but I'd have to pull it out and look... It was around $20...
Welcome to the site.
peyton
10
houston, tx
Thanks,
Jeff
Jeff, the manuals can be downloaded and are in the tech manuals section; look under resources. The manuals are TM5-6115-585-12 and TM5-6115-585-34. I thought the -24p was there as well but didn't see it.
If you can't find the gasket, RTV should work.
Peyton
peyton
10
houston, tx
Which filter (brand, number) is shown in your picture? Thanks
Peyton
papercu
31
Baxley, Ga.
filter
First, my info is for reference only. I cannot say which/any filters will fit your equipment.
The filter shown is a WIX 51004
Height: 4.809
Outer Diameter: 3.984
Inner Diameter: 0.765
Nominal Micron Rating: 24
Gasket Number: 15090, O.D.: 4.955, I.D.: 4.400, Thk.: 0.062
truckfest
glenmoore pa
RE: filter
Thanks to all! I do have a WIX51004 filter, it does have a flat gasket, the onan takes a "square o ring"type gasket.WIX tells me the WIXPC202 is no longer a good number and to use the51004. The NAPA1004 is made by WIX ,i do not know what type of gasket it comes with.Does anyone know if the NAPA or the FRAM CH6PL has the correct one?I did talk to someone from cummins [i understand cummins owns onan]they need a part number for the gasket.thanks again ,jeff
papercu
31
Baxley, Ga.
gasket
This is from the TM,
Gasket, oil filter assembly NSN is 5330-01-200-4808 part number 102940 and you csn try this one 122-0404
BTW If you do get a correct maker/number be sure to post it in the Parts Cross Reference section under the Resources tab. Wayne
