mep 004 frequency meter&co It turns off when I put in run the switch
sgarfa
udine italy
Good afternoon everyone, after a rebuild of the injection pump (for which I have also removed the alternator)...at the restarting, the voltmeter and the frequency meter are switched off when i release the starter motor and put the switch in run position, if i put back the switch in start position when the genset is already running for a few seconds the meters restart to work...i've tried to verify the alternator connections, i've studied the manual, but now I'm a little in trouble:sad::sad:
some illuminated person has some idea?
Guyfang
23,029
Burgkunstadt, Germany
When you start the set, hold the S-1, start switch up longer. It sounds like you do not hold the S-1 up long enough. The generator needs to get a signal from the speed switch to excite the main get. If you let it go too soon, the gen set will not excite itself and it makes no power. So that's why the volt and hertz meter do not show anything.
sgarfa
udine italy
thank you so much of the answer, but I usually keep te start switch up for few seconds until the frequency meter starts to measure, but now when i release the switch to run position the meters go to 0, tomorrow i try to put the start switch up for more seconds...
thank you so much
