1800 Diesel
- 25
- 18
- Santa Rosa County, FL
I'm doing some outdoor mechanic work this evening (sleet/rain mix in the FL panhandle) and will be running one of the "bench units" to power my air compressor, several heaters & lighting. The last time we ran this unit it shut down after about an hour of running. Fault indicator light for "no fuel" was on. I expect I'll have the same problem with it later this evening since I haven't had the time to sort out the problem.
I suspect the float switch for the day tank is not working or what else could it could be?? The priming circuit & fuel pump works properly via the battle short switch. Basically, whenever it shuts down, all I have to do is re-prime/refill the day tank and get fuel to the IP & it lights off with no problem. BTW, when this happened last time the main tank was about 2 gallons low when I tried to refill it. So the problem is not that the unit actually ran out of fuel but instead related to the day tank running down and not getting refilled.
Thanks in advance if anyone has any ideas.
Update edit--Ran the unit last night for about 3 hours and noticed main tank fuel level did go down like it should. I topped off the main tank whenever I could and this time there was no auto-shutdown and of course, no "no fuel" fault indicator. By the fact that the main tank level was going down, wouldn't that indicate the float switch & fuel pump was working properly? I'm thinking the problem is an intermittent failure of either the float switch or the fuel solenoid. Not sure what else it can be.
Kevin
Kevin
