- 18,166
- 27,283
- 113
- Burgkunstadt, Germany
Now take a jumper wire and connect it to P80N. The engine should start.
You should also get Under Volt and Under FreqFrom what a gather the top right corner is the low oil pressure light on the fault indicator. Also it should light up as soon the run switch is activated. This is why I'm saying it is not lighting up.
Kris
