Sorry for the slow response.
Sunday night was a tough loss for me
But we wont get into that right now however I still think we should have won that game...
We will be back though!!
Any way I took the liberty of taking a few pictures of the throttle so you could see what a normal operating one looks like and how it should work.
So this first picture here (the one all the way on the right down below for some reason inline did not work) shows the throttle in the closed position or otherwise all the way in (Hz are going to be very low in this position avoid running here you will possibly burn up your voltage regulator!)
SO this second picture (middle picture) shows mine with the thorttle at about 60 hz for my unit. TO get it there just push the button in and pull it out or if you feel like taking the long way to getting there just keep twisting it in a CCW fashion till it is extended out to about this position. One thing to note notice that ring with the lines on it where the throttle bar comes out of the side wall of the generator. If you twist that to the CC direction it will tighten up the friction setting on the throttle so that if its not holding its position very well it will hold better if you tighten up that friction nut.
And this (the one on the left) picture is just simply showing you pushing the button in as you move the throttle in or out. Pretty easy cheesy.
