mikemike1
- 14
- 3
- Dennison/Ohio
Ran fine before except hz fluctuated some found inspections seals leaking on injector pump and changed them then found transducer leaking and put a new one in ...now it will run only ten seconds and shut off. The low oil pressure sensor light on the panel is lit but the oil gage is showing 30lb during the ten second run. Did we get a wire switched or sensor bad ......... as reading switch shut off is 17lb +-3psi and saw there was a reset button on the oil pressure sensor is that what I am missing? Advice please
