Sephirothq
- 26
- 48
- Trevorton / PA
Ok I got my engine running with a rebuilt pump from badger diesel. But now i am having some issues on the generator end.
First the load gauge shows full load for some reason without anything connected.
Second at as much throttle I can put to the engine I am only at 59 HZ. I have tried to adjust the frequency and the knobs turn but have no impact on the frequency.
Third. I only have around 104 volts instead of the 120 volts. When i flash the field by holding the start switch up it goes to 120 volts as long as the switch is up.
Fourth the close / open switch doesn't seem to work either. Power is at the lugs reguardless of that switch.
Do I have only one problem or multiple as far as teh boxes go?
Might I have an issue with the generator head itself?
I just got the unit running so i haven't had alot of time to play with it yet.
