- 18,088
- 27,149
- 113
- Burgkunstadt, Germany
If you have a soldering iron, remelt the trace. Sometimes it helps. If not, put the A4 back on the wall. Then take the K1 relay out. Spin it 180 degrees, and put it back in. Then test the A4 again for continuity on A4-7 and A4-9. Sometimes only one set of contacts stop working on these relays. If it still doesn't work, then we will do this. If you have a spare K1 relay, simply plug it in and test the A4. If you do not have a spare K1, we will do some "field" repairs.
Remove the Fault indicator. Take the 5 screws out on the left side of the indicator, pull the plate out. There before your eyes should be a relay, screwed to a circuit board. Remove it, and plug it in on the A4 board in the K1 socket. Then test your A4 card. This should fix it. If so, then you need a relay for your fault indicator, but that's not such a big thing. The set runs just fine without the indicator. But it sure helps you figure out why the darn thing stops in the middle of the night.
The relay is to be found in the internet. There are some that have a price about the same as the GDP of Uganda. If you look hard enough in the net, you can find cheap one. If you need help finding one, I have the time.
I should thank you for giving me something to do.
