Mep 007
derby
S.E. MI.
I have searched all over this site and I can not find any info for this set. Can anyone point me in the right direction.
derby
S.E. MI.
Is this a rare unit? I can't find anything on it. We just got one at work and as the only MV buff there the boss threw it in my court, You guy's are making me look badrofl
31
-7
Oshkosh WI
Thank You! I do not know if it is an A or B. I will check on Monday. So it has a Cat engine?
MEP-007A has
Cat D333C (T): 6 Cyl, 4 Stroke, Liquid Cooled, Turbo Charged Diesel with 170 HP @ 1800 RPM
MEP-007B has
Cat 3306T: 6 Cyl, 4 Stroke, Liquid Cooled, Turbo Charged Diesel with 217 @ 1800 RPM
31
-7
Oshkosh WI
It is an MEP007A, Is the only difference between the two the engine, and is one better than the other?
The engine is the only difference that I am aware of. The basic difference between the engines would be the Injection Pump, most of the other engine parts are interchangeable. Don’t worry though; the MEP007A has full potential to run your 100 kW load. The MEP007B is just a MEP007A that has a little more power.
31
-7
Oshkosh WI
I found this in the 100 kW MEP007A Parts Manual. (TM 9-6115-646-14P)
"1-11. Differences Between Models. The PU-495A/G and PU-495B/G differ from each other only in regard to the model generator set utilized by each. The PU-495A/G is equipped with an MEP-007A generator set whereas the PU-495B/G uses model MEP-007B generator set. The only difference between generator set models is the installation of different diesel engines. The performance of both engines is similar and therefore there is no significant difference in specifications between generator sets or power unit models."
Boreal21
Central Utah
Sorry to bump an old thread, but didn't feel like this question warranted it's own thread.
I looked for the TM mentioned above, but it's not listed on the SS resource page. I'm looking for all TMs related to the MEP007A/B since I just bought 4 of them :drool:
I will check the forum listed in one of the previous posts in this thread, but any other direction would be appreciated :beer:
Boreal21
Central Utah
Quick research suggests that there are only 2 manuals for that genset:
TM 9-6115-646-14
TM 9-6115-646-14P
Oshkosh... do you happen to have an electronic version of those TMs you wouldn't mind sharing?
Boreal21
Central Utah
Perfect!
All links worked great... manuals are printing now. Thanks a lot for the help!
We don't have coffee or beer here, but if you ever travel through Utah I'd be glad to buy you a hot chocolate or kool-aid :beer:
bar1
United States
Does anyone have any info on mep 007c ? They say they have been updated by wheeler power (the cat dealer I take it). I would kind of like to know how much has been redone and if parts are available- just starting out here any help would be appreciated - all the info I find is on the mep 007a and b.
Munchies
Keesler Air force base/ MS
$$$$$$ Digital cat controls . I dont mean $$$ in a good way. Parts can get expensive.
Cat engine for sure, might be a cat gen head, its been awhile, might have been marathon.
bar1
United States
Mep 007c
I have actually just purchased one and everything works( needed some adjustment of the breaker actuator - simple). I was curious if anyone had a manual available for one of these? I realize parts could be expensive, but being Cat I believe parts should be readily available. I believe it to have a lima / marathon head ( after Munchies response I looked and found a manufacturers part number on the gen head and traced that back to Lima Electric who has been purchased by Marathon; So thank you Munchies - you made me look harder:-D) and the controls appear to be completely Caterpillar , so I may be able to obtain manuals that way, but was hoping for the military TM.
