MEP 016a/c electronic ignition directions
redlight
Boston/mass
Greetings,
Saturn Surplus has the conversion kit with out instructions. Is there a copy somewhere?
I have an old 016a that I want to get running however it has no spark. I will be installing a new fuel pump to get fuel to the carb but it needs spark to run.
Redlignt
redlight
Boston/mass
Hi Guyfang,
I have downloaded both engine manuals and I am reading them now. The add from Saturn surplus refereed to missing documents so I want to see if anyone had a copy.
My unit has not been started in about 10 years and i wanted to make a go of it.
Redlight
Guyfang
22,191
Burgkunstadt, Germany
I looked through the manuals, could not see anything concerning the mod, but it looks straightforward. I did about 18-20 of them, but so long ago, that most of the members of SS were not born, or going through puberty. I can not remember anything hard about it.
Is Saturn willing to promise that all the parts are there? If so, you just ought to go for it, if the price is right. They are good engines, and after the mod., they are great engines. The only problems you will have afterward is maybe a fuel pump or carb. If its been that long since it ran, pull the carb and soak it in carb cleaner, or JP8 or kerosene, something to take the lacquer off the carb. That was the biggest problem area for this engine. The Carb. We ran 24/7 and 365. If the oil level starts to increase, or oil gets thin, you need a fuel pump.
I will continue to look for the mod paperwork.
redlight
Boston/mass
Thank you. I will change to fuel pump and I have cleaned the carburetor. I hope it will run. I have most of the change over parts I will call Saturn to see what is missing and order what i need.
Guyfang
22,191
If you buy a kit without the instructions or paperwork, you should at least ask if all the parts contained on this parts listing are there. The kit is NOT complete without each and every one of these listed parts. Same list, pictured twice, for 100% clarity.
