MEP-016B Genset with an Onan
Jim_in_Omaha
Hello. First post here...
I recently purchased a 016B with an Onan diesel. I only wanted the engine to mess around with. At the surplus store it was the only one out of four 016b's that the engine appeared to be worthy.
I removed the engine today and the injector pump was sticky. After about two hours soaking with carb cleaner it freed up. I applied 12v to glow plug for about 30 seconds. The engine then fired up with about two seconds of cranking. I was impressed since I don't know much about diesels.
Is the glow plug 12v or 24v? I assume 24v but can not find a diagram.
I have been looking for the technical manuals. I have TM 5-6115-615-34. But it does not go into great detail regarding the engine electrical control. It makes many references to TM 5-6115-615-12 which I have not found. It requires a username to download off the military documentation site. Any help would be greatly appreciated. Great site for info.
Jim
1,168
Hi Jim! Be careful, I started out monkeying around with military generators years ago and now I have 2 M35A2's in the yard!!! :oops: This stuff is addictive! Sorry I don't have the info you are after but hang in there. Someone here will come through. Welcome to SS!
Jim_in_Omaha
I found searchable PDF's of all three manuals using some cryptic wording on Google. The glow plug is 12volts. Glad I didn't hook up 24v.
I'll upload the current manuals when I get a chance. I uploaded the old one I had but after looking at these it is very obsolete. Will need to fix that...
And I would agree this stuff is addictive. I also have a 4A032 engine.
thanks
Jim
Isaac-1
SW, Louisiana
I can't help on the glow plug voltage, but can tell you mine (MEP-701a) will reliably start without needing the glow plugs down to below freezing.
Ike
