ETN550
- 9
- 0
- Knoxville, TN
Anyone have the wiring diagram for the resulting conversion? (Not the engine diagram and not the TM for the gen side) My electric transfer pump that pumps from the belly tank to the engine tank is not working and it is not stuck. What's the little device mounted by the start switch in line with the pump wire? Is it a resistor to drop the voltage to the pump? Also there is a larger square electrical device on the pump wire. 2 of 3 units have it one does not? Just got some of these 016Ds from the GL. They are a little different than the 016B I'm used to. Picked up an E as well. Maybe I should collect the whole alphabet??? A-E Not much of a gas fan though.
