MEP-016D fuel tank and starter?
rothroq
Central KS
Has anyone tried a 12V to 24V transformer on the starter?
And are there and suggestions on a replacement fuel tank? The filler neck was distorted enough on mine to require a new cap, filter and tank. I've only found standard replacements without the extra taps and such.
Isaac-1
SW, Louisiana
Why worry with 24V, it is a series wound starter motor, and supplies enough speed / torque to start the engine if the compression release button us pressed first when jumping from a 12V battery.
Ike
p.s. there is no such thing as a DC to DC transformer, the closest thing would be a DC to DC converter
Also does yours have a plastic or brass tank, if brass why not braze on a new neck
ETN550
9
Knoxville, TN
If you are talking about the steel tank mounted on top they can be found on e-bay to fit the Chinese knock off engines. Search for L70 or L100 fuel tank. Some are sold with all hardware and filter. The big fitting that is on the bottom of the 016D tank is unique to the 016D. It appears brazed on the tank. Should be able to un-braze it an install it on the replacement tank after making a hole in the new tank to accomodate it.
6x6TRex
Flint, MI
A 12V to 24V converter that will power the starter is going to cost way more than what you paid for the mep. You would need a couple hundred amp capacity converter to power the starter. Either use a bigger 12V battery or 2 smaller 12V batteries wired in series.
rothroq
Central KS
Thanks for the info and tips! I'll try the 12V jump start.
The tank I have is steel and wanted a used replacement but if the tank has brazed fittings, I'll brush up on my torch technique and attempt the swap.
