MEP 017a Low Voltage output ?
ron87777
bellefonte, PA
I did turn the main generator over and it moved, No ac, when I broke down generator and removed the Housing I could see where mice chew the wires. When I tried to move the stator it would not move at all. I would like to try and fix the wires. I will try your suggestion. Thanks for getting back.
ron87777
bellefonte, PA
Guyfang
27,160
Burgkunstadt, Germany
Ron,
You should start your own thread. More visibility, and no one will start look at at the first posts in this thread. Its several years old. If you are not sure how, give a shout. I, or someone will walk you through it.
Please take a picture or two of your gen set, so I can see how far and what's still attached.
Guy
