I found a great deal on a MEP-112a generator last summer. The seller included a 60Hz generator head from a MEP-003a generator for converting it over.
![20190629_171826.jpg 20190629_171826.jpg](https://www.steelsoldiers.com/data/attachments/561/561157-aefc7e4897258d68d34b45cc390f23f9.jpg)
I researched it and discovered that I would also need a different control panel and output box as well. I have a non-running mep-002a and found that the output box could be converted for a MEP-003a by removing half the loops of wire in the current transformer to make the output breaker trip at the higher 10KW output. The control box from the MEP-002a should work ok on the 003a according to what I researched. I found one thread on here with a little information but it mostly confirmed they had switched it after the fact. I hope to add a few more pictures of the work in progress and go over the process. If anyone has some experience to add to this please chime in.
![20190629_200929.jpg 20190629_200929.jpg](https://www.steelsoldiers.com/data/attachments/561/561158-6b04d6287ec51869e44f82a30372fe48.jpg)
First I took off the control panel. It mounts with 4 vibration dampers that have a single bolt from inside the control panel. Most of them ended up just spinning the mount and would not come loose. If you look at the mount where the control penal bolt screws in there is a round hole in the side. I used a punch that fit the hole to hold it from spinning while I removed the bolts. Disconnect the large connectors from the back. There is a small ground strap on the bottom of the control box that goes to the frame, be sure to disconnect it.
Next I removed the output box. That was pretty simple. Just remove the connectors then there are 4 bolts in the back of it. Then remove the front cover and there are two more at the bottom edge.
Next I removed the metal frame that hold the control panel and fuel pumps. Disconnect the fuel lines coming from the tank and the one to the injector pump. Disconnect the 3 Packard connectors going to the fuel pumps and label them so you know where they go. Disconnect the connector from the fuel solenoid. There are 6 bolts around the edge of the frame.
![20200711_080130.jpg 20200711_080130.jpg](https://www.steelsoldiers.com/data/attachments/561/561161-4b2ca0830a8093486c45effa210bb1eb.jpg)
![20200711_114027.jpg 20200711_114027.jpg](https://www.steelsoldiers.com/data/attachments/561/561162-a379fc6ade3ad99750b75759f8e98a75.jpg)
Next remove the 2 fuel tank straps, the connector for the fuel sender, and the fuel return hose. Lift the fuel tank up and remove it. This allows access to the bell housing bolts and generator mounts.
![20200711_080102.jpg 20200711_080102.jpg](https://www.steelsoldiers.com/data/attachments/561/561160-acc22749ddf9ac266fb3aded51f5b8d0.jpg)
