loadmaster
- 0
- 1
- hurricane/wv
I am trying to get my auxiliary fuel system working on my generator. I have hooked it up to 24VDC and the pump worked for about two seconds and then quit. I ran it after the test and the pump would not work. I applied 24VDC power again after I ran it, and the pump will not work at all now. I have replaced the relay in the float switch but still not working. The float switch is receiving power at 28VDC and I am wondering if other components need to be replaced, pump, heat sink, ect. I am not even sure what the other components do and I am wondering if I can bypass them or if anyone knows where to get replacements. If you do, part numbers would be greatly appreciated. This generator will run about two hours off of the gravity tank but I would love to be able to use the belly tank. Also I have been trying to disconnect the fuel pump to bench test the whole system but I think I am going to have to cut the positive wire to test it, unless you guy have any tricks. Any suggestions you might have to help me get this thing back to fully fictional would be really appreciated.
