- 14,606
- 4,691
- 113
- Buchanan, GA
I'm looking at one of these gensets on a trailer. The pictures provided aren't the best. I'm guessing the tires/wheels/bearings aren't up to highway speeds are they?
Hi GuyfangIf you get this set and need TMs, say something. I will upload them.
If you get this set, Do read the -12 TM. It has about a million warnings. Most times the warnings are overblown. Not on the MEP-362A. It has has been known to toss a turbine blade or two through the casing.
The igniter can kill you if you are fooling with it and it pops off. If you test the igniter out of burn chamber, do wear good sun glasses.
Turbo shaft oil, and I seem to remember the number MIL-L-7606, is a known cancer causing agent. Use ONLY the oil listed on the LO, and DO NOT MIX two different oils.
Avoid the exhaust air out let when running and for a half hour after running. We used to heat up can of food using the outlet air.
Insure that the Fuel Shutoff and Drain valve is not plugged up. It discharges unused fuel from the burner chamber. Too much fuel in the burner can can cause a "Booming Start" If it ever happens, you will know it.
Turbine gen sets are the only gen sets I would tell someone to read at least twice the -12 TM, and at least once the -34 TM. And read all the trouble shooting guides, before trying to start the set the first time. Having said all that, I like them very much. If you be careful of them, you wont get bit. Or destroy anything.
If you decide to put a different gen head on the turbine, Do read and follow the run-out, (Alignement) procedure. The set will want to shake itself to pieces if its not done right.
Thanks Guyfang!Its in the upload forum as I type this!!
