baja
- 0
- 0
- LaVentana, Mexico
I am a newby so figured I would start with small and move my way up. I now have a MEP-531 that had 81 hours, changed the tubing, primed it, ( have a old diesel truck so these two issues I am use to), then changed the oil and it started right up. Runs smooth and no smoke. It shows 120VAC on the panel. But no power on the service outlet and none at the power terminals, and used my voltmeter to test the terminals (inside and at service box) and the service outlet. Reads zero voltage AC.
I have not checked the panel meter on the genny with my voltmeter yet, but when off it shows zero and generator running is showing 120VAC. Before I have to page through all the technical manuals I have downloaded though I might ask, Is there a reset switch/circuit breaker? that i am missing?
note, did a forum search and very little is written on the 531.
