UMR_Engnr
- 0
- 0
- Olathe, KS
I recently bought a MEP-701A with the ONAN diesel engine. I have been trying to prime it but it doesn't want to. It didn't feel like there was any resistance on the prime lever, so I removed the fuel pump. That is when I discovered the transfer rod was all the way in the up position. So I reconnected the fuel pump and ran the starter. After that, there was resistance on the prime lever so I pumped it for quite a while but there didn't seem to be any progress. There was no fuel in the fuel filter. I removed the fuel pump again and placed the inlet in a container with diesel fuel and left the outlet open to the air. If I actuated the prime lever it would suck up fuel but then releasing it would cause the fuel to go back into the container instead of expelling air out the outlet. I opened up fuel pump and there are some one way valves but then there is also a little hole that appears to connect the inlet and outlet that allows air to flow back through the inlet.
So my question is what am I missing? Is my fuel pump behaving appropriately? Is there a check valve somewhere in the system that is stuck? Is there more to this process that I'm overlooking?
Any help is appreciated. I really want to get this thing up and running. Thanks
