Auctioned 09 vintage 802 arrived on Monday. 10hrs on the clock and apart from some road dust on all the flat surfaces its spanking new. Manual in plastic, ground rods in place on the skid, aux fuel hose and ground wire tie wrapped in door compartment. I was told the 2HN batteries were no good and on closer inspection I noticed they had never been put into service - bone dry and still had the red shrink wrap on the caps marked "remove seal when battery is activated
". I purchased acid, filled and charged. Will be starting up tomorrow.
I guess the 10 hours on the clock were all via NATO jump plug starts.
Now for what I may need help - I found a 2" copper buss bar with what looks like a 12mm and an 8mm hole in the ends along with nuts spring and flat washers. Not the ground neutral strap as this is in place at the lower right on the load terminal board. I'm wondering if it may be a buss from the back side of the terminal board that has rattled off?
Thought I'd consult the brain trust before I go and remove the terminal board tomorrow for a gander of the back side.
just had a thought - is this bar possibly an alternate method to connect to the top of the ground rod?
![image.jpg image.jpg](https://www.steelsoldiers.com/data/attachments/483/483345-e62722575c3106eb6ef891622586a09c.jpg)
